Beavis
Still plays with trucks
It started with the door locks working when they wanted, Some times they work like normal and other times one will work fine and other won't. Tested voltage on the actuaters and that checks fine, and also replaced the relay under the dash (which didn't help).
Also some time later, as I was driving, the dome light decided to come on all by it's self and not go off. Checked most of the obvious stuff like dimmer switch, rear window switch, and keyless entry module with no luck (disconected them all as the light still light).
Not sure if these are linked together or seperate but would really like to resolve it. Any ideas or leads or encounters like it with solutions would be great.
Thanks...
