MRKING
New Parts for Old Trucks
I just made a tunerpro log and only let my sy idle . I did tap the throttle twice so see if the rpms would drop and they seemed to dip a little but it went right back up to 3k and holds steady .
Basically just seeing if theres any hidden info that could indicate where i should start looking . The truck starts good and does run good at the 3k . Ive set the distribtor and verified timing numerous times .Double checking each time read 0* with the tan wire unplugged, and per the tunerpro dash i believe it was 30.23 timing with the tan hooked back up .
The vac is at or around 14 while high idleing and honestly im stumped . Ive been going from small issue to small issue and this is where im at . Any help is appreciated :tup:
http://www.mediafire.com/?sharekey=117a4d7643fde6856e7203eb87368129e04e75f6e8ebb871
