DM file, could use some opinions.
Sy_Zero484
I just put in a new knock sensor..what a bitch. I did a highway blast and didn't record any knock, but I swear I can hear it. Maybe there's something loose making the metallic sound?
Anyway, I would appreiciate any opinions and suggestions on the log. I noticed on most of my logs that this truck likes to pull a lot of fuel. And after looking at some other peoples logs, I just noticed I never get a Boost Tgt. I also get alot of Data ERRs, especially at WOT. Is that normal or should I play with the ALDL Timing and REC speed?
http://rapidshare.com/files/402988088/NEWKNOCKSE2.uni
Modifications include:
Walbro and hotwire, ATR 137A, Borla catback, K&N, new turbo, fresh tuneup, IC scoop, 180* stat, tranny cooler, and engine tie down.
Thanks in advance..
Sy_Zero484
Re: DM file, could use some opinions.
If you've looked at the log you probably noticed the intake temps are high. I just disconnected the EGR line and plugged it...the intake temps came down to 120's with a max of 133 at the end of 3rd. Not great, but better.
DM says the TC is locking, but when I do the brake test it shows that it's still locked and I feel no change in RPM. I checked the switch on the brake pedal and it seems to be adjusted fine. Any other tests or suggestions?
