streetmodz
i heard that you can disengage the front prop shaft so you can run with two wheel drive. how do you do this?
streetmodz said:i heard that you can disengage the front prop shaft so you can run with two wheel drive. how do you do this?
Hu Ryde said:Others have gone several thousand miles with no problems just make sure you fluid is not low and still in good working condition and you will be fine. But, why do this unless doing burn outs or long travel? In general we have the upper hand with the awd system.
streetmodz said:Hu Ryde said:Others have gone several thousand miles with no problems just make sure you fluid is not low and still in good working condition and you will be fine. But, why do this unless doing burn outs or long travel? In general we have the upper hand with the awd system.
no doubt about the awd. btw after 6 years of dreaming im picking up my first sy #0024 next saturday.
