Don't come here much anymore, so a bit of a late reply. There is a lever on the turn signal stalk that pushes a rod that goes down the column to the actual switch. What could have broken could be the plastic on the turn signal, or the actual switch which is located toward the fire wall where the wiring plug is visible. I can't remember if you can visually see the rod/switch under the dash without taking the column out, but I'd try that before tearing the upper column apart to replace the lever in the turn stalk. I rebuilt the tilt column on my truck.... and if I was close, I'd give you a hand, Don. Hope this helps. Chip
