Did anyone here try a upgraded W2A like this?
R&C_RallySyTy
Little Big Man
I always see auction on ebay and other turbo stores offering upgraded water 2 air ic stuff. Does anyone here have anything like this? I thought about trying it but would like to see what others have done.
H-TOWN-TYPHOON
You're killin' me, Smalls
Re: Did anyone here try a upgraded W2A like this?
qbnkiller...i think.
I have seen at least a couple of those in use, just can't remember the usernames.
Loeryder
Just watch the CFM capabilities.
If they are designed for superchargers then they might not be as efficient in the higher CFM range our turbos often see.
ViciousV6
400HP/550FTLB
These are good if your going to running a Ice Box and water pump and cycle the water through an ice box. We are so limited on under hood space placement is always an issue. These are good for racing applications but for people that drive their trucks everywhere A2A will keep the temp the best for driving it.
Ralph
R&C_RallySyTy
Little Big Man
Ralph
Thanks Ralph. :tup:
NecroWolf
lost marbles member
i seen someone with something similar to that. the routed it through the holes for the hvac system and had it mounted in the cab on the passenger floor board
qbnkiller
Conflaguration Specialist
yup...I have one similar to this. Will be building an icebox for it next year. I also have a much larger heat exchanger underneath to help with the IAT's.
I'm sure someone has pics from the Detroit BBQ a few weeks ago.
jwaller
Evil Genius/SyTy Guru
the hoovers old truck has something very similar to this.
nello
there is a pic of a setup like this here:
http://www.sytyperformance.com/fabrication.php
bottom left pic.. 6th image in slideshow. We did the one for Jamie H. and he dropped over 60 degrees from his A/A if i am not mistaken.
Mike, Where could you put a BOV w/ this setup, image6? Any pics of one added? Appears air would flow very nicely. Whats the H20 capacity? All your pictures look ta ta tiiiightttt. :tup:
aNYBOdy else out in syty land know the capacites of the STock IC system? How many ounces of coolant is maxed?
qbnkiller
Old pic....cleaned up a bunch under there. IAT's are pretty good still.
Silly
Banned
We got one sitting up at the shop in rockford... don't think it has a use as of right now but if anyone is interested I can get a price for you.
PM me if you want a price, it is not my piece so i would have to ask for you.
nello
I did just figure out how much liquid flows through a stock setup...:tdown: a measly .59375 gallon, or 29oz for lower cooler/exchanger (pathetic), 20oz for the upper garret w2a box and average 13.5 oz remain in each of the soft lines. SHit is weak!
QBN thanks for the BOV pic...nice setup.
Syclone0565
CustomMulticades.com
I had a setup like that on mine. I will see if I can get a pi. Went to a A2A. I have the A2A, pump, relay, hose, and some pipe, couplers, switch, and 3gal black summit tank if your interested. I can let this go rather cheap if you want it all. :)
Email me if your interested as I don't always follow up on all threads I post on :tup:
