Re: datamaster
Preface, I haven't looked at your logs. My tuning laptop is getting old in the tooth and isn't working very well on the internet anymore.
It isn't unheard of the boost to drop down that low with the stock waste gate & actuator. If the ECM is trying lower the boost while the engine is shifting into 3rd, the boost can sometimes drop drastically. A forged waste gate would help your truck run faster, because it doesn't vary as much as the stock boost control. Your average boost would be more.
I am not sure what your goal is for your truck, is to run perfect as is or to eventually modify it? Once you getting running smoothly according to scan tool you probably want to ween your truck of off high octane mix. if its running 100% it should run cleanly on a scan tool with the stock chip and 93 octane.
