I did a couple runs on datamaster and could use a little help. The TY is being held back dramatically by something and nothing seems to stand out to me on the log.
For reference, I have a 20G 14cm turbo, RPM CAI, 3 bar map sensor, MSD Blaster, TurboTweak VeloSYTY chip, stock torque converter, 3" cat-back exhaust, Walbro 255 fuel pump, 160 deg thermostat, larger IC pump, stock injectors, replaced vacuum lines, stock ignition control module, newer plugs-rotor-cap.
I have 2 files.....test1.uni was with the map sensor set at OEM, test2.uni was set at 2-3 bar setting. The very last "hard" run was a moderate boost launch on both logs. The RPM's got high on the second run because I forgot to put it in OD....too busy watching the laptop.
The TY has an obvious surge during hard acceleration and wants to go fast but cant. I did not notice the check engine light come on while doing these logs either. I am guessing it is a fuel issue but would very much appreciate someone with more experience looking them over.
Anybody up for it? I can email them to you directly.
:tup:
:tup:
