atc82
The truck has 50lb injectors, TE-61, built tranny with 3K stall, meth injection, and a custom chip from Nolan.
Over the last 3 weeks or so, datamaster will not stay connected to the ECM while under boost. It will also disconnect while just cruising, but it only does this occasionally. Almost anything over 12-13 psi and it looses the connection, only to regain a few seconds after I get out of it. During a boosted launch, it looses the connection right after takeoff and will reconnect/disconnect a few times during a run.
I have the aldl port, ecm case, and wideband 5V output from the LM-1 all grounded at the same place. After I did this the situation didn't get any better.
I am using a Belkin USB adapter and I have tried the new Beta version of datamaster that has the option for USB connectivity. I have also tried two different ALDL cables, both from AKM, and I still get the same result. My laptop uses XP. I use to use ME, but I am not sure if this could be the cause. Anyone had probs with XP?
We have always had some data errors while logging, but never to the point where it would loose the connection to the ecm until recently. Tyler let me try his ecm from his typhoon and it didn't help, so the ecm is not the problem. Also tried logging while the alky system is turned off and got no change of results.
I don't really know what to try next. The truck runs awesome, thanks to Nolan, and doesn't show any signs of a bad ignition component. I use Taylor wires, Conrad cap and rotor, and NGK UR6 plugs. The rest of the ignition is stock. I read several posts here and I am not the only one that has had this problem. I found several threads here and tried what they suggested. (checking grounds, grounding ecm case and aldl port to same place, etc)
any ideas on what I should look at next? Its hard to tune the thing when Datamaster won't stay connected to the ecm.
