50/50 WATER ALKY OK IN smc kit? I put the 220uF cap after the fuse on the feed before the relay. OK? Wouldn't ti drain the battery? What pump speed do you all run at w/ which mixes? I break up over 4 on straight alky turning on at 11 psi w/stock boost levels.
Jeremy
Orig post here:
http://www.syty.net/phpBB2/viewtopic.php?t=12878&start=15
Jeremy
Orig post here:
