Won't this cause your frame to flex even more under heavy launches? Doesn't seem like a good idea to me.
DaveP said:The t-case isn't that heavy. Of course you know that now that it's out. I'm a little skinny guy, and I routinely lift them in and out by myself. You could have asked us the weight. About 60 Lbs.
I had an old Dunstan tubular crossmember that I put back. Only problem is he made it wrong so its not ideal nowso I will have or make a new one this winter but for now its going to work.
opcorn2: I would interested in one of those...
How are you guys getting the brake lines out of this piece? I looked at it today and I really don't want to have to undo the brake lines - it doesn't look simple. I'm thinking about using a Dremel tool or Sawzall to cut around the cables. I'm planning on removing this next weekend and will replace it with the custom RPM chromoly crossmember/driveshaft loop.
Never mind, I finally got it out..
Hey Denny - how did you end up getting that crossmember out? I removed the bottom bolts today and plan to take an air chisel and mini-sledge to it tomorrow. I'm curious how you were able to finally get this out and how long it took. Not looking forward to it at all, but I need it out since my 80e and t-case are ready to go back in the truck as one piece. Let me know if you have any pointers, thanks.
Cool man, thanks. What about the welds...how did you break those? I think I'm going to try cutting the rivet heads in half with a Dremel and then breaking the pieces off with a chisel and hammer. I hope the e-brake lines are easy to unhook. Not looking forward to it (agh).
