Corvette Rims
Richard Le
Re: Corvette Rims
Yeah stockers are light and fast. 19's and 20's are for show and not for go. It takes a lot more energy to spin 18's, 19's, and 20's.
92TyLA
Re: Corvette Rims
I think it looks awesome, and ofcourse I think this guy knows those wheels are for show only, aslong as you have a set of stockers or smaller wheels for the track.
nice sy:tup:
goozy808
Re: Corvette Rims
Well, everybody has a opinion and I respect how you guys feel but at the end of the day its my truck and I love how it looks. Im fixing it just the way I think it should look. Anybody with common sense knows that my truck is a show truck, not a track truck. Of coarse its not going to run any 9s or 10s but as long as it runs up to par and looks good, that's all I want. It's crazy because when people see the truck they think its something that just came out especially with the rims on it. These trucks were built basically 1 year so they are limited addition and when I fix up a car I want to make it look like it shouldve came factory like this!
Neelsonwheels
Re: Corvette Rims
Thats what is all about.
Make it yours and enjoy it!
The only one that needs to love the truck is you.
Good luck.
Richard Le
Re: Corvette Rims
Well, I'm glad the factory didn't put 19's or 20's on it. Otherwise, performance figures in magazines wouldn't be something to write home about, and the September 1991 issue of Car and Driver wouldn't have pictures of a Ferrari 348 and a Syclone on the cover.
aasltmike
Re: Corvette Rims
Factory suspensions on most cars weren't designed to handle 20's and bigger. That's why I laugh everytime I see someone with wheels like that with a suspension that wasn't upgraded to handle the bigger wheels. Makes me wonder the thought process behind blowing all the money on them wheels when about a year down the road, they have to blow that much money and more to upgrade the suspension components that went to s**t from them "oooooo-neato" wheels...:2cents:
goozy808
Re: Corvette Rims
Can I get anybody to answer the questions about the wheel diameter? Is it a inch, half inch, or less than that. I'm trying to get some advice about that issue not how the truck looks or how you would of done it! We can start a new post on how I'm going to need suspension, bigger brakes, etc.
Richard Le
Re: Corvette Rims
What more do you need to know about wheel diameter? It's obvious that the diameter for the front and rear have to be very close to each other or you will destroy the transfer case. It's also obvious that they have to be close to stock diameter.
Here is a great tire size calculator: http://www.1010tires.com/tiresizecalculator.asp
Just punch in the stock size (245/50-16) and what you have now, then compare the results.
goozy808
Re: Corvette Rims
Thanks, but I already used the size calculator and im just trying to get some advice from people that have experienced what I am going through.
whitechocolate
Re: Corvette Rims
Hi i would like to know about tire size would
245/40r/18 front 285/35r/18 work without damage to anything
dia 25.71 dia 25.85 .14diff
thanks for your help
Black Knight
I Glow Therefore I am
Re: Corvette Rims
Actually, you want to reduce the rear diameter. Stock diameter is only 25.64, so you will be over 2" larger in diameter if you go with 27.9. Your speedometer reading will be around 5mph off.
He could always regear it with 3.08's, correct me if I'm wrong but that should bring it back down to 3.36 pretty close to stock, might be an option.
whitechocolate
Re: Corvette Rims
stuckinUT
Re: Corvette Rims
Depends on the overall diameter of the tires, but half an inch and probably less for sure. It is supposed to be within like 1% difference. Use the calculator. It was hard enough for me to find tires within spec for 17" fronts and 18" rears that were reasonably priced.
And with tires that much taller than stock your performance braking and acceleration wise has to be noticeably worse. Regardless of how light those wheels are, aluminum is heavier than rubber. Our stock wheels are very light. When I took off my stockers and put on billet 17" front and 18" rear, even being billet they were ever so slightly heavier than stock, and my tire height is .1" shorter than stock with the tires being within less than 1% height difference front to back.
That and with the tires being almost 2" taller than stock you have effectively changed your final drive gear ratio, acceleration will be slower, braking will suffer and your speedo will be off. For instance, my wife's daily driver, a Mercury Marauder, came stock with 3.55 gears. It is heavy, and the 32v ford motor isn't know for it's low end torque. One of the quickest and best ways to make that car faster is to throw in 4.10 gears. The difference is crazy. What you have done by putting on tires that are almost 2" taller than stock is the same thing as me putting 3.08 gears in my wife's car, which would turn it into a complete pig.
Don't get me wrong, I like big wheels if they are the right design and tasteful for the vehicle. I think your truck looks good. Would I have done it? No. But how it looks to you is what matters. When I put 20's on my DD Jeep I caught a lot of flack from the other Jeep 5.9 guys, but I think it looks good and that is what counts. It DID effect performance though, so I race with the stock wheels on.
You just have to take into consideration the "collateral damage" to the drivetrain and performance. You will need taller tires in front to not damage the transfer case, you will need to re-gear to a numerically larger gear to regain performance and you will need bigger brakes to regain braking performance.
Plus tiny brakes behind big wheels don't look good. I hate my stock brakes behind the 17s/18s on my Syclone.
goozy808
Re: Corvette Rims
Thanks for the advice. I think I'm going to go with the 275/35/20 rather than the 285/35/20 because I don't want it to look bulky up there. The truck just got out of the paint shop and is now in the interior shop getting a cloth tonneau cover. After that I can try the tires to see what works.
