Not really.. There is a pipe plug just above the oil pan rail on the drivers side. If its never been out then the hole is prolly covered with sludge/rust. You'll get a face full of coolant when you poke a screw driver through it once the pipe plug is removed. Just ask me how I know :wink: .
On the passenger side you can take the coolant return line from the turbo loose and get the same result. Its also just above the oil pan rail in the side of the block.
Either way is messy but other than draining the radiator then pulling the bottom radiator hose thats the only other way to get the coolant out.
