I realize you are answering my question for me......I'll try another gauge this weekend.
Somewhat related to this... but does anyone have the part number for the gasket/o-ring for the block adapter on hand? Mine is leaking and I figured while I have the front diff and t-case removed giving me a lot of working room, I could replace the lines and seals. Get rid of the minor oil leak happening down there.
I went doing the conversion last evening and can now confirm, that in the remote housing is not the same adapter. First, it seems shorter and second, it did not had allen hex socket inside, so it could not screwed out from the housing.Is the adapter (GM part#14081300) the same part that is in the remote oil filter housing? Can you just re-use it if you pull it out of the housing?.
BTW, our Finnish/Swedish users can use following part for replacement, if needed...1) Here's the adapter you need. Make sure you clean it well if you're using a used one. Short side goes into the block.
