My Typhoons transmission is acting kinda funny and I was hoping you all could point me in the right direction.
It will shift to overdrive at around 47mph but it feels like the converter is always locked up. Once it hits high gear it falls on its face (falls to about 1400rpms). I even have to use a couple lbs of boost to merge onto the highway or climb hills. Should I be able to feel the converter lockup at a higher speed or anything? Is there a way to tell if it is locked up or not? Is that normal for these trucks or does it sound like I need to adjust something?
Also, I can make the truck kick down if I gun it, but it only stays in low gear for a second or so and then upshifts again.
The 700r4 was rebuilt recently and has a 9/11 2800 stall in it if that matters.
Thanks in Advance,
Dustin
Thanks in Advance,
Dustin
