Re: compatibility with standard s/T trucks
Fixing noted discrepancies:
-rear end is a standard GM 7.625" , with G80 code 3.42
-driveshaft is stock
-propshaft is same as bravada
-transfer case is stock bravada stuff
-front diff is standard 3.42 bravada, but the right axle tube is syty specific
-tranny is standard 4L60, but it has a different valve body, servos and clutches
-If drivetrain includes motor... the block, rods, cam and crank are stock, as are the heads, for an LB4 motor. pistons, intake/exhaust manifolds, DP, etc are not same.
-Halfshafts are stock
-hubs are stock for a bravada (they have a different part number, but they are interchangeable)
-brakes = stock
-Converter is higher stall than a normal S-Truck (from another GM app, not sure which)
And Shuggs... some day someone might have the time to compile that list, but not in this forum :lol:
