Well I had picked up this TY ive been trying to sort out all the things not working on it but im not thebest at tracking electrical issues down or maybe this could just be simple fixes.
First off is my wiper motor only works on high, when its placed on any other portion other then high on the wiper stalk it will stop and not do anything is this A. The wiper stalk or B. the wiper motor resistor im guessing it has this under the plastic cover on the front of the wiper motor? or C. some other crap?
Secondly my AC only works on HI when switched to any other speed it will turn off the blower motor and not blow I have installed brand new OEM ac blower switch and blower resistor, I see these trucks have a blower motor relay that's bolted to the plastic ac box could this be my issue? I have not changed the relay.
I also found that theres a Ground wire going to the AC compressor clutch that is not factory when I cut wire the Clutch will not work with switch on dash on or off, but when you reconnect the wire the clutch will then work on and off with the switch on the dash, I do know that the wire is a GROUND wire and not power, Whats the reason for this rig the switch on the dash isn't bad cuz its turning on and off the compressor clutch right now on a daily.
also the cruise control it doesn't work its all hooked up in the time of me owning the truck it hasn't worked has a new set of sportsmachines vac lines installed correctly, all electrical is pluged into CC unit and cable is intact. Could this be the wiper stalk giving me issues? or is this something else I really don't know were to go on this one.
A little help with these issues would be awesome.
