In step one of metering the coil my meter read open loop. Step two .9ohms, and step 3 9.07ohms. So what we have here is a bad coil right because step one is open? Is it ok to use a coil from napa, autozone etc to replace this one?
If you look on the cd page 6d4-6 in the jimmy service manual you will see how to test the coil with a meter. I am thinking that the distributor or the coil is going bad because that's the only 2 parts left that have not been changed. My ty will not hold an idle. It has been wandering for a while but now it's just awful. It stalls all the time.
basically the question i have is what does the term "infinite" mean while reading these books? Are they referring to open loop or a dead short? I did a search for coil and someone else has their meter showing 0.1 for the first test and mine shows ol. One of ours is bad i would think.
Update. The coolent temp sensor was bad causing the computer to see a cold motor thus dumping more fuel. I am however still interetsed in finding out the correct value for the coil.
