coil over suspension question
TurBowtie
this has probably been brought up before but... i'm thinking about getting a coil-over front end but i don't know much about it.
can you still have AWD or is it a two wheel drive conversion or what any cutting you that sort of stuff.
Anyone with the coilover let me me know how it works and all that.
myclone
Re: coil over suspension question
You keep the AWD with coil overs (unless you want to go 2wd). Minor trimming of some some brackets but no all out cutting.
Quickstop [UK]
Combating adversyty.
where you getting them from?
I have just been looking at blazinlow.com for blazers and jimmys etc as well as S10s. Will their S10 stuff fit our trucks?
And what is a reverse 4 link?
jjorgensen52
NHSTE - I'm the only one!
Their stuff, almost exclusively, is for 2wd trucks. I would suggest either Race Proven Motor's or JS Manufacturing's coil over kits. I have RPM on my truck, my brother has JS, both are great kits.
A 4-link is for the rear end. It locates the rear axle using 4 forward facing control links and 2 shocks. Sometimes, all 4 arms are parallel, 2 above and 2 below the axle. Other times there are 2 below and the top two come inward in a triangular shape. If it has a panhard bar (side to side location) it becomes a 5 link. There is also 3-link (Ivanko on board has a custom 3 link).
The only difference in a reverse 4 link is that the arms face rearward.
