CODE 42 Running weird??...SOLVED!!
tygraine
team green racing
Got a code 42 the other day after the truck started running weird. The tach jumps up and down, it doesn't respond to throttle when I hit the pedal to get past the stumbliing. If I hold the pedal to maintain the speed it gets me home. I replaced the module, and the ECM, but not the pickup in the distributor. I also took the 3bar, and Ultimate out. It does it with the stock chip, and 2 bar. It seems that the hotter it is out, it makes the situation get worse. At idle when cold, the tach dips a little at idle, but other than that it runs strong. I let the truck sit for over a year, It started up fine, but has this problem now. I almost forgot, the ecm won't comunnicate with my friends snap on solas scanner, and when I short out the aldl, it sometimes doesn't flash anything, not even the code 12's....Any input would be really appreciated. Thanks guys!!
tygraine
team green racing
Re: CODE 42 Running weird??
I replaced the distributor... truck runs a lot better. The pickup must have crapped out.
tygraine
team green racing
Re: CODE 42 Running weird??...SOLVED!!
Replaced the ECM....It was fine on the cooler days, but when the daytime temps got up there, the truck would totally run like crap.
nastety92
Why don't you stop throwing parts at that thing and drive it. DAMN.
Team Green Racing
Nick
tygraine
team green racing
Drive it every day bud, it's all I have left!! The Ty is my daily fuggin driver...get your garage queen out on the street!! I get it...you need permission huh?
Talk to ya soon broham ;)
nastety92
HAHAHAHA, you know its a garage queen. It will be one day when you get done painting it.
I wish I could drive mine, but I'm still waiting for the damn TC to come in. Hopefully by September it will be done and ready for NED.
Lata,
Nick
