code 32
darkchylde
Has anyone pulled a code 32? Book says egr circuit. I pulled the valve and it holds vacuum. The vacuum lines are brand new. The check engine light seems to only come on at highway speeds (45+). The only other thing I can think of is that egr controller thingy but that looks expensive (actually it looks cheap but gm is probably gonna try to tear me a new one). I've had this code pop up every once in a while since I've owned this truck. Any insights welcome. (blockoff plate comes to mind :grin: )
1TiTeTy
same thing happened to me...i took off the egr, cleaned it, and put it back on. Fixed the problem. Also the line to it was a little loose fixed that as well...still no problem...Same deal with it comming on at the highway speeds. Also if i did a hard launch with 4 -6 psi. Still has not come on and I have done, many more launches.
2cold
I had a code 32 last week and it was caused by a vacum line that blew off. Double check the vacum lines.
