Code 31
skwayb
NWSTP
Re: Code 31
I would check the vaccum lines on the wastegate solenoid to make sure they are still on there. I had mine come off a long time ago and it threw that error code.
I would also put datamaster or Tuner Pro on there and see what your target boost is, wastegate duty cycle % and Actual Boost is to see if you are overshooting. If you are overshooting you might need to adjust the wastegate rod. Especially if the code 31 keeps occuring.
