CLR in upper and lower IC?
Mephisto
These trucks are cursed
my upper and lower IC look like they've got a nice fair amount of calcium and whatever else kinda build up inside them... most likely the previous owner was using all tap water in the system.
anyone tried soaking these in a tub of CLR with good results?
teamvortec
Re: CLR in upper and lower IC?
I have used Eagle One's aluminum brightner on radiators before and it helped a lot.
Captain Morgan
Moderated User
I use muriatic acid, just gotta make sure you dont leave it too long and neutralize it after you flush it out
0966Sy
Code what?
I know Prestone makes a cooling sys flush bottle that works well. CLR product is very good at what it's designed to do. I may run a couple ounces through my ic system. I know it's got some crud from the tap water
Mephisto
I dunno that I would run CLR THROUGH your system... it's gotta be pretty potent to really do anything... a stronger mix might not be the best thing for the IC pump???
I've never had much luck using vinegar on this type of stuff... couldn't even clean my coffee maker.:lol:
