Re: Clogged cat, how do I know?
IIRC Code 43 is usually tripped when the computer attempts a self-test of the knock sensor and it fails. Basically the computer creates a scenerio that it knows will create knock(too much timing). It then listens for the knock and if it doesn't hear it it will throw code 43 and put you in limp home mode(reduced power, timing, boost).
You should hook up a scan tool and start logging with the engine off.. Then lightly tap on the block with a hammer and see if your knock counts increment. If they don't start troubleshooting your knock sensor, wiring from knock sensor to ecm, etc..
Good luck..
