Re: cladding
Cladding is attached via pop rivets and screws. The screws are the easy part. Pop rivets will need to be drilled or grinded off. You will notice that many of the cladding overlap. This does cause difficulties.
The tabs that hold the cladding on often break (they are actually part of the cladding). If yours are broken, then you will have to have them glued back on. This requires some kind of special glue or you will be wasting your time. I have had some temporary success with gorilla glue and cloth fabric but the commercial stuff done right is the best.
Hope this helps and good luck.
