Chip source in canada ?
vortecfiero
I will be deciding shortly whether to buy a chip burner or emulator
and im looking for an inexpensive chip source here in Canada
the way i see it...
emulator more expensive up front but no chips to mess with till im tuned
burrner less expensive but after a bunch of chips are done depending on the cost of them
the outlay will be close to the emulator or more expensive
I dont plan on fuel or spark tuning myself because Id rather let someone, who already has gotten their head around it, do mine for me
I do what to play with the other stuff
eg shift light - cool toy because not all applicatons are automatic
and could also be used as 12v signal for something else (as i get into it id be glad to share the results)
and of course boost control.... etc
Re: Chip source in canada ?
chips are reusable, so that isn't a big cost
Once you buy an emulator though, you don't want to go back.
10secTy
Sy-Ty builder and Tuner
You already have the flash chips from moates. So just get a flash and burn and be done with it. You will not have a ton of tuning to do on your set up so this way you will sit down and go over a datalog and make a change then you can go test it out.
Emulator is nice but you do not want to leave it in the car all the time I have had issues in the past.
Nolan
turbodig
the way i see it...
Willem programmer... ~$45 (Ebay)
256k flash chip... ~$9
Moates G1 adapter ~$35
< $100, you're up and running.
vortecfiero
thanks guys !
im a complete newbie with this stuff and have a ton of reading to do.
the moats burner is on its way.
i have 2 chips that came with my adapter so hopfully next week i can make a few simple "adjustments" like being able to shift at 5500 like I used to (its an L35):)
vortecfiero
I have edited and burned a few simple things to a chip...
Id love to find a place in toronto or nearby as a source to have a couple extra
to make back to back tests.
