Checking overdrive servo
How do you check the overdrive servo?
I heard you can remove this without taking out the transmission. How do you do that?
jwaller
Evil Genius/SyTy Guru
Re: Checking overdrive servo
the 4th and 2nd gear servo are located in the case on the passengers outside near the front.
they are held in by a snap ring and can be tested by applying air from the pan rail and viewing the servo pin thru the window behind the front pump area. if you remove them I suggest you replace them with a better billet versions available from sonnax.
