They should. keep in mind your going to lower it another 1/2". And they are no longer made in steel, they're aluminum.Peter W. said:That is exactly the look I want. The rear wheel is perfectly center. One question, the angled lowering blocks I have on the truck now, are they compatible with these back plates? If so, I just place these back plates underneath the lowering block right, and the lowering block should lay ontop of the back plate nipple, correct? Thanks
i just dissassembled my stock leafs yesterday, to pull the factory wedge out, so that I can use it on my Belltech springs. Question... My Belltechs have a spacer on them alreay, they came like that. Do i remove it and install the wedge?? or do i leave the Belltech spacer, and install the wedge?
I installed the wedge.
Putting the spacer on top of the wedge will screw up the wheel positition again.
Put the wedge on top of the spacer.
