Re: Celsius ---> F* in Tuner Pro
I didn't want to have multiple versions of the tables in TunerPro in F and C. All of the notes on Temps in the P4 document were in C and so were the notes on how the tables were setup by GM. So I decided to keep them that way and leave the Temps in C.
You could make the changes yourself to have it in F. Take a table. Write down all the C values for the ROW or COLUMN that is being displayed in C, convert them to F, then edit the table definition in the XDF and put in the new F numbers for the ROW label or COLUMN label you are changing to F. I believe all of the TABLES only have a ROW label that is in C that need to change to F. Example: Tables F31M and F31, the ROW labels are in C. and the data is a multipler. So you only need to change the labels.
Now for CONSTANTS, you need to change the formula. That is what is used to display the number in C. You would need to change the formula to display the number in F.
Example: The constant, Temperature for Closed Loop is in C. The formula is 0.749020 * X + -40.000000. You would need to change it to 1.348236 * X + -8.000000 for it to now display the results in F. Provided I did my Math correct on that formula.
Hope that makes sense.
