Numerous times over the years people have asked about timing and why the engine won’t run or runs poorly. Common answers are “you’re 180 out” or “you’re a tooth off.”
Those comments or a variation of them seem fairly common. I’d like to know the original source but these two thoughts are probably at least as old as I am.
Neither one hold any water so-to-speak. If the timing is “180 out” then you’re firing the cylinders at TDC on the exhaust/intake portion of the cycle. The engine will not run.
Being a “tooth off” is equally meaningless. There are 13 teeth on the dist gear. Consequently each tooth equals aprox. 27.7 degrees of timing. That far off in either direction will cause all kinds of problems. Starter kickback, backfire, or just plain no-start, but regardless it’s very unlikely the motor will run or if it does it will be running extremely poor and require some throttle to keep it going.
I recently installed my dist a “tooth off.” It wouldn’t even begin to run until I rotated the dist counterclockwise a bunch. In effect compensating for the “tooth off” install and bringing the timing to a point where it would start. IE rotating, or advancing, the dist 27 degrees to “compensate” for the “tooth-off” install.
So it really doesn’t matter where you install the dist. Or where someone else installed it. With the engine on TDC COMPRESSION, obviously the most important step, drop in the dist or look where the rotor actually points. That is now #1. It’s as simple as that. Then, in our case, going clockwise, insert the plug wires in order: 6,5,4,3,2. As long as all, including module, wires will reach without stress then NOTHING ELSE matters. Not the position of the gear on the shaft or anything. Of course physical limitations like wires reaching, personal preference, (“this thing is going in like original if it kills me.”) or if on an older vehicle with vac advance the vac advance unit may dictate dist placement witch -will- have an effect on the resulting rotor position and wire order.
The one exception that I know of is certain air cooled VWs retarded the spark ONLY on #3 which required the dist to be installed correctly to provide for that.
Although a :rant: hopefully this will serve to clear-up the kind of questions that occasionally come up when we have no-start, backfire, type ign questions.
