Can anyone with Taylor wires help me?
Fighting5thSVT
I took off my old plug wires back in September. Finally getting around to putting new Taylor wires on.
If you look on the cap side of all of the wires, there is a number. The number starts with KW--followed by a 3 digit number. The wires I got from Hood Tuned look like this:
KW519 ( 90* boot )
KW528
KW555 ( 90* boot )
KW557 ( 90* boot )
KW620
KW650 ( 90* boot )
Can anyone tell me which wire is used for each cylinder? I want to make sure that I get the fit just right. At best, if anyone knows which cylinders get the straight boots, that would at least be a start for me....
Here is a pic of where the ##'s are. Its blurry, but you get the idea. I did a search on these and found nothing. This would be a huge help for me if anyone could take a few mins and look at their wires.
Thank you guys very much:tup:
[/IMG]
i8av8
Re: Can anyone with Taylor wires help me?
on my truck i have the straights going to cyl. 5 and cyl. 6. the others get the 90 deg. boots. can't confirm #s since i didn't know there were any. sorry. hth!
BoostedSUV
i have the straight ones on #1 and #6.. the rest just make your judgement by length.
Brassmonkey
Cruzin' Mel Man
It does not actually matter which cylinders get which boot, just make sure the wires are as far away from the exhaust as possible, the down pipe too. I suggest you use boot insulators anyway, just to be sure. They are cheap insurance.
sytyguy
Moderated User
What he said. If routing all the wires neatly, I like to give Cylinders 2 & 5 the longest 90 deg wires (they have to wrap to the opposite side of the dist cap). 3 & 4 can run fairly short wires.
Fighting5thSVT
Wires are on. I measured them as close as possible to the info in the link provided by Big Mike. Wires are on and all is well. Thank you to all that chimed in:tup:
