brian
All of this problem is because the 412 does not give a linear progression of power. Instead it gives it all to you at the bottom end. Had i known this i wouldnt have used it.
as for the big drag radials, sounds like a good 1st step. Maybe it will work well enough that i can skip doing the external stuff and just use the controller for 15 psi launch and then higher boost after launch. Hopefully with a lot of praying and fingers crossed. At least i can start with that.
What wheels work on our trucks that are wide enough for these larger drag radials with the different front and back offsets using 17 inch size?
I assume fender clearance is fine with these sizes?
Can i drive on 2 dif sizes for the 20 mile round trip to the track without hurting the transfer case clutch or am i going to have to swap tires in the pits doing this?
Guess i should have long talk with tony about his setup.
I plan on talking with tom ferrick about this as i am sure he and harry went through this problem in the past also.
Harry just keeps telling me to yank the cam and he will tell me what to use that has a linear curve to it. Harry tells me its easier to go 10's if i did that.
Im just dont want to go back into the motor yet.
Besides my goals are only 11's and driving daily without borrowing an exhaust pipe at 2 year emissions intervals.
