blk00z28
Forced to by choice
No one wanted the package, so here's everything parted out.
Add shipping to all prices(which I will get quotes for on heavier stuff, most everything else will easily do the flat rate boxes/envelopes).
-Bowtie Heads
p/n 1404883 (Raised runner 23*) 60cc chamber, 2.00 intake, 1.60 exhaust (don't remember make, sorry), Comp 98541 dual springs, Viton 11/32 Seals, Jesel shaft mount 1:6 rockers(with brand new hardware and brand new rocker rebuild kit) Flow (i/e) 6" - 280 - 205 - $1,400.00
-Brodix intake
p/n - 10093314
This intake is not ported!
Comes with fuel rails, 1" spacer and forward facing 90* plenum.
It has been milled on the china wall flange .010" to clean it up.The ports have one bead of weld in the top side of the port to make fit the above "raise runner" head. You will need to mill the runner gasket surface due to small amount of weld protruding from the runners(this is a 15 min job for a machine shop and might cost $25) and possibly polish(or port) the added material in the runner.(it WILL bolt on any 23* bowtie/brodix/pontiac head perfectly). - $525.00
-Comp Cam (brand new in box) gross lift(i/e) .538 - .531, Duration(i/e) 224/224, Separation 115 - $215.00
-A2A 20"x11"x2.5" IC (it is 30" long from tip to tip) - $95
-Victor Reinz short block gasket rebuild set - sold!
-Jeep steering shaft - $25
-Taylor spark plug wires & taylor spark plug wire boots - $75
-Mini starter - sold!
-Accessory brackets-the set-(power coated black) - $95
-MSD hei coil - $35
-MSD digital 6 connector - sold!
- ARP head studs - sold!
-ARP intake bolts - sold!
- Cometic Head gaskets - sold!
- RPM 23* sheet metal perimeter valve covers - sold!
- Billet weld on oil filler - sold!
- Billet weld on AN male fittings - sold!
- Intake gaskets - $30
- RPM sheet metal 100 degree sideways facing plenum - sold!
- 90mm Accufab throttle body - $sold!
- (6) used 75# low impedance injectors - sold!
- Comp Lifters for 4.3L - sold!
- Edelbrock double roller timing chain - sold!
Pictures of everything:
-Bowtie Heads
-Brodix intake
p/n - 10093314
-MSD hei coil - $35
