SY2932
Administrator
PART 1
Okay so you decided that you don't spend *enough* time under the hood of your truck as is and you want to spend even *more* time. First off, I would like to apologize for not being true to my original post on this very subject, "polishing a turd". Even though I eluded to the shortcomings of polishing my intercooler and upper intake, I did like everyone else and posted pics that showed the good:
but not the bad:
and the ugly:
The bottom line is these parts were NEVER meant to be polished. The impurities that are inherent in ALL the intakes that I have personally seen both polished and unpolished, coupled with the rough casting makes them undesirable to do so. On my intercooler, there are spots that are now so thin, I can push on them with my finger and it feels like the bottom of a soda can... I already mentioned that I hand sanded through two spots and had to get it welded
. The techniques in this write up were not "modified" in anyway now that I "know better" from doing my own parts. My approach from the get go was to "remove as little material as possible to achieve a satisfactory finish" based on the experiences of others who have done this before me. This is not meant to scare anyone off, I'm just trying to "keep it real" so anyone who decides that they really want to do this knows what they are getting themselves into...
This write up will consist of two parts, part one is polishing i.e., sanding away the rough casting marks to make and smooth surface so that we can buff it to a mirror like finish. BTW even though polishing and buffing are used interchangeably, they are not the same. Polishing means sanding to smooth surface and buffing means giving the surface a mirror like finish. Anywho, before we can start we are going to need some tools and equipment:
For you folks out there who don't own a decent air compressor, this is a great time to invest in one. A corded sander isn't going to cut it on an intake simply because there aren't very many flat spots on it. I get most for my polishing supplies from the gentleman that sells to where I work, Dave Glenn of Artco (American Rotary Tools Company). His number is 586-909-2231. Usually, they have a minimum order requirement but I spoke to him about it the last time he stopped by. He said that they would overlook that since you guys prolly won't want to buy several hundred or a thousand or so dollars worth of polishing supplies/equipment at one time...
The 2" 3M Grinding/Sanding/Finishing Kit can be had at Autozone of Walmart for under $20 and you will be able to get quite a bit done with this alone. It is important to note that this is a twist lock type system whereas the disc is threaded in the center. I have the "hook and loop" style as well but I don't care for them as it is difficult to get the disc dead center and when you are spinning it at several thousand rpms, your finish will suffer as a result of the disc being off center.
I got the braided air line from Artco and I couldn't work without it. When you are working with a tool for hours on end, you want to comfortable using it. The braided line weighs nothing and you forget that you are even connected to the air compressor. I have an inline pressure regulator that I bought from Harbor Freight on the end where it attaches to the shop air. Makes it so that I can run the grinder "full throttle" by simply adjusting the line pressure. That way, I don't have the "feather" the throttle to get the right rpm that I want.
Undoubtly the biggest aid in sanding has been discovering grinder's grease a few years ago (that is it to the left of the 3M kit in the pic above). That can be had from the Eastwood Company. I prevents the sanding discs and cartridge rolls from loading up when sanding aluminum. It makes a HUGE difference. A little goes a long way, my tube is over three years old and I haven't even used a third of it yet.
Now for a word on safety. You will DEFINATELY need a dust mask especially when you start sanding. It makes a HUGE mess. I also wear an apron if that tells you anything... Depending on how loud your grinder is and your proximity to the air compressor you will want ear protection too. I do the bulk of my polishing and buffing at work since it has a huge air compressor that is housed in another building so I never even hear it running. I have a Craftsman 6HP 33 gallon at home that never stops running and I have to stop after about ten minutes to let it "recover". The safety glasses are a no brainer since sanding and high rpm's are involved.
Ok on with the show
. The owner of the donor intake had painted the emblem so the first thing that I did was tape it off so that I could bead blast it out. The tape is to prevent pitting the aluminum surrounding the emblem. Even with VERY low pressure, it will still pit the material. For this reason, I would not recommend blasting to remove the coating that is on it. You will be VERY sorry if you do...
Here, you can see a mount that I made to hold the intake when I am working on the top. Due to it's shape, it isn't very stable when resting on it's base. Which brings me to an important point. The upper intake is a cast part and it should go without saying but, be VERY careful handling it. If you accidentally drop it, it will SHATTER like a clay pot! The mount works great when you are dressing the area that the emblem is on as you will see later. It is simply a 2X4 with a piece of plastic between it and the intake protect the sealing surface from getting dinged up while I'm working on it.
This is the aftermath of a 50 grit sanding disc. If you have never power sanded anything before, it is very important to KEEP THE TOOL MOVING AT ALL TIMES! If you don't, you will put a decent sized gouge in your part VERY quickly! At this point you are probably asking yourself what did you get yourself into... You can see that I have a towel under the intake since I am working on top of a steel bench. Anytime sanding is going on, the grinder's grease is close by. At this point I move on to the next grit. You may ask why when there are still patches that didn't get sanded clearly visable. Remember my goal: "remove as little material as possible to achieve a satisfactory finish". The reason is, you will remove MORE material as you progress through the various grits sanding. Ideally when you get to your final grit, there should be very few spots that you will have to address since you will have sanded to the level they were at. This is something that only experience can teach. Fortunately for the most part, the upper intake has plenty of meat to it. Therefore, the chances of you sanding a hole in it if you get over zealous are minimized.
Time for some more tools and equipment:
A long reach die grinder with a selection of cartridge rolls in various grits to get into those places that the sanding disc's couldn't. Grits are 80, 120, 240 and 320.
Cleaning up the valley here. Note that the intake has been sanded with an 80 grit followed by a 120 grit sanding disc at this point.
Just to show that there is still more than one way to skin a cat, here is the results of bypassing all the sanding discs entirely and going straight to a 3M Scotch-Brite disc. These are the last item that I use powered on the flat surfaces before going to block sanding. This can save you some time and doesn't make *quite* as big of a mess and you don't even need grinder's grease to use them. I prefer to use the sanding discs because it is easier for me to see where it is cutting at.
Obviously, this is the most time consuming part on the intake. You are going to need even smaller tools to clean up that mess:
Dremel 395 varible speed rotary tool with a flexshaft attachment to get into the *really* tight spots. As well as a selection of ceramic "Super Stones" to sand places no rotary tool can get. If you are on a buget, you could press a Dremel style tool into service where the long reach die grinder was used previously.
but not the bad:
and the ugly:
Ok on with the show
