Re: Bravada Disc Brakes
warmpancakes said:
Hes looking at the rear brakes, but you are correct about the front stuff
Y'know, I feel like an idiot.....
I read the original post and for some unknown reason thought he was talking about rears....
I've got a 99 Bravada, and here's what I can tell you:
1.) Front brakes are too small for a V8....Turbo V6 would be in the same or worse condition (and that's with the 2 piston front calipers). I'm sure the 2 piston calipers and associated brakes would be a step up over the older smaller disc, but I don't think its enough, personally. It needs ALOT more brake....
2.) Those rear discs are expensive. I ended up having to replace some parts when I bought the truck to get everything fully functional, and those things are more $$$ than the C5 or F-body brakes (both of which are bigger). However they do fit in stock wheel sizes and are a bolt on affair which I don't think can be said for some of the other potential upgrades. And on the plus side, rear brakes do alot less work, so they're not nearly as important.
Good luck with whatever you decide to do....
'JustDreamin'
