Brake setup question
JoveDios
1993 Gmc Typhoon #0627
I was just wondering what's the easiest and best combo set up for front and rear discs with calipers on 17" wheels. I wanted to go with discs in the back and upgrade my front brake calipers. Thanks
hatrik8
Re: Brake setup question
I did corvette c5 z06 calipers in the front and rear. The fronts were easy to install. Just needed to modify the spindle and get a bracket, lines, rotors, calipers, pads. I haven't done the rears yet. I have the parts, just haven't gotten around to it.
I'm sure there are easier combos and better combos, but I liked the look and performance of what I ended up with.
Black Knight
I Glow Therefore I am
This is the least expensive, and best bang for you buck with that size wheels.
My only suggestion is using 98-02 F-body rear disc so that you can run a parking brake and they are almost identical in size and flavor to the C5Z rear discs.
WOTracer
Well as far as easy and direct fiit I would go the 1998+ 4wd blazer front disc brakes with 1998+ 2wd rear disc. Everything is a direct fit including abs and parking brake. It could be very inexpensive if you go the junkyard. I think I picked everything for under $80 . A lot of the u-picks places have 50% every Tuesday. I personally used the old calipers for cores and got new calipers. They gave me $115 dollars back for the cores, which paid for my junkyard parts plus enough for lunch!
berzerker
wookie
rear brake upgrade is easy choice . just do the 98-02 camaro rear brake install .Complete set up used on ebay can be bought for under $250.00 . Just search under ls1 camaro rear brakes . p.s. dittch the crappy abs !
Black Knight
You can do that, but they also noted best, and after doing the F-body/C5 swap on 4-5 Sy's it is a better swap IMHO.
Your call though, the one mentioned above is not a bad idea, just not what I would do. The modding for F-body/C5 is so minimal don't let that deter you from it. If you can work an angle grinder you can tackle this project in a good day.
JoveDios
Thanks a lot guys for the info now I just gottah decide what to do
bshaw1979
You are correct .I did the c5 Z06 fronts on mine and I couldn't believe the difference for such a minimal cost.
hatrik8
I already have the C5 z06 rears and stuff, but no parking brake. Is there a way to combine the 98-02 F-body rear disc with the parts I already have so I can use a parking brake? I wasn't worried about not having a parking brake because I've never used it in the 9 years of owning my truck.... but I'd rather have it and not ever use it than not have it at all.
JoveDios
Can you post pics of your set up
hatrik8
This is what it looks like with 18" rims now
GarnetTy1473
I was able to pick up a complete set of C5 Z06 calipers and rotors for $400 shipped off of a corvette forum. Bought the Renz kit for the front. Had a friend of my dads make the caliper bracket for the rear, and Renz had some rear brake hoses made up for them. Turned out nice. I can have him make another set of brackets if you want. Think they were somewhere around $100.
randy merritt
Here are mine with 17" rims.
The fronts are 12" C5.
The rear are 11" "LS" from a junk yard with new rotors. The parking brake does work because I used the Renz bracket, and flipped the calipers to the rear.
hatrik8
No parking brake, right?
