Braided AN Hose Tools
Captain Morgan
Moderated User
Re: Braided AN Hose Tools
a bench vice w/ 2 blocks of pine
leather gloves
electrical tape
WD-40
sharpie
die grinder w/ cutoff wheel
open end wrenches (or the fancy aluminum ones you can buy)
warmpancakes
i wrap the fitting with tape then a adjustable wrench, I have the sof jaws for the vice makes a world of difference
4C FED
Absolutum Dominium
Good pair of tin snips & 2 hands.
Assemble right away before the braid begins to flare.
TYHOGG
I have a large gauge cable cutter from greenlee. after wraping the hose and cutting with these things i will never do it any other way. The cut is the cleanest i've ever seen on braided hose, and the fittings are a snap to get on.
MikeRenz
not stock
i got aluminum an wrenches and a pressure test kit which is nice for double checking. chopsaw and elec tape worked fine for me :lol:
Bustedsm
Numbered Car Crazy
Sharp ass chisel, nice piece of copper or brass to keep the chisel from dulling and a hand sledge. That's for cutting...
Otherwise, adjustables :(
sytyguy
Moderated User
:rotf::rotf: $14 for 6" of angel aluminum with a strip of magnet tap in them, I hope they come with some KY too
$14 if you buy from Summit or Jegs or whomever.....never said you should do that. :?
Let's just say that you can find those much cheaper if you wanted them.....ahem, me.....ahem. :tup:
skwayb
NWSTP
Amen......I did blocks of wood for 2 years and since I got the soft jaws in 2000, I'll never use anything else. For those who don't have a vice with soft jaws, you can use these:
3" - http://www.holley.com/004ERL.asp
5" - http://www.holley.com/005ERL.asp
After making a ton of AN hoses, I would highly recommend these. Hell if you complain about buying these for $14, then you shouldn't be making AN hoses. Heck I have a couple of fittings that were $25 a piece. Rather not mar them up. Once I got those I stopped putting little nicks in my fittings or taking the finish off.
If you decided not to get AN wrenches, then make sure all of your wrenches you use are very smooth on the inside. Something like the finish of the Craftsman Pro Series Wrenches. Anything with that finish will not muck up the fittings. Also like Pancake said, wrap the fittings before hand with good old electical tape. Makes it less likely you will scratch the fittings.
sytyguy
Moderated User
Agreed, at the track, we have a nice adjustable wrench that we sprayed the inside of the jaws with rubber coating. We use AN wrenches 99% of the time, but the coated wrench works when you're trying to make good time.
QWERTYphoon
Motley Driver Award 2009
this is how I have been doing it. I didn't have an aluminum block like that, so I use an old 3" drop block I had left over from a previous truck. You don't really need any special tools. The masonite chisel I found at Home Depot. I sharpened it on my bench grinder. First time I did this it worked perfect. As long as your wrenches are chrome plated it will not marr the finish on the fittings.
http://www.anplumbing.com/installation.html
MikeRenz
not stock
and if you do scratch something, you can just cover it up with red paint. that method is ghetto, even for minnesota. Surprised you don't just use a wood chipper to cut it down.
QWERTYphoon
I would use my wood chipper but it is full of aluminum beer cans........red paint is cheap.....why you suppose they paint barns that color?
turbot
aeroquip vice jaws and aeroquip crescent wrench. the an wrench wears out way faster then it should spend a couple extra bucks for the crescent never have to buy another one as long as you don't lend it out.
AutoVation
I'll sell them cheaper too. $4...
+ $25 s/h. :2cents:
100% refund guaranteed (less s/h)
