Boost
93 typhoon
Hello evry one i just installed RPM air2air intercooler very nic. I took the truck for a rid to day and it runs good. But i notice that wen i hit max boost 17,18 psi the boost gauge starts jumping and the truck starts runing a littal bad. had this hapend to enyone. Can it be leaking air throw the pips? it never did this. can some one help me with this. THANKS
Bill Z
Re: Boost
Yes. Can be leaking. Make sure all of your connections are tight.
gjp
another post whore
Re: Boost
check the one on the TB. Mine was leaking there. Once it poped off. Scary thing to see your boost guage go from 15-0 in a flash and hear a loud pop.
93 typhoon
Re: Boost
It was the one from the TB i found out wen it poped off under boost. I mad shore it's on good know. thank you guy's for the help :)
Black Knight
I Glow Therefore I am
Re: Boost
Do you have a bracket on there that ties the piping to the TB so it can't come off? If you don't and still have problems I would search out this braket it makes it so it really can't back off.
gjp
another post whore
Re: Boost
Mike said there is a thicker coupling for this. I made a gheto bracket for mine. Looks like crap but holds 20lbs of boost. Oh and I was free and took me 1 hour to build and install.
93 typhoon
Re: Boost
no i have the normal clamp that came with the kit. i took the truck for a drive did not come off yet. but if it give's me problems i will let you know.
hay take a look at my truck it's in cardomain.com it's the one that say Here is my 1993 gmc typhoon more pic coming soon.
93 typhoon
Re: Boost
do you have any pic's of this bracket i will like see.
gjp
another post whore
Re: Boost
its gheto, and looks like crap but it works. As you can see I have the top strap tightened all the way. and it still poped off.
93 typhoon
Re: Boost
gheto but it works. if mine keeps poping I will make one :tup:
