Re: Boost Vs: Octane Question
It is not that simple of a question. The cylinder head design, pressure (note this is not intake pressure), and temperature determine when gasoline will pre ignite. Changing timing, camshaft (timing), turbo's, intake flow, pistons (slightly different cr) all affect this.
A stock turbo peak efficiency is at 14psi; higher boost pressures it starts to heat up the intake charge. For a stock turbo, heads, cam, usually you can get about 17psi on a good running motor on a stock timing. (some can get more/some less). Because inefficiency of the stock turbo at higher boost pressure, the stock turbo peaks out in the 18-20 psi range without additional cooling (alky). With higher octane gas your most likely would want to add more timing. To get the most out of your engine, you really need to experiment with increasing the timing or boost one at a time and monitoring with it scan tool, AFR, and ideally reading plugs after a run.
