Boost Solenoid Question
JOE27BAJA
Hi I have had my TY for about 5 weeks and only drove it about 30 miles. Today I went to remove(delete) the factory air box and I noticed something on the boost solenoid. If you are looking down at the top of the solenoid there is one port on the left side and two ports on the right. The top port on the right has a line going to it and the botton had no line at all going to it. I looked all around for that line and cannot find it. So my question is do any of you know where this line connects to, I feel like a D.A. for even asking ...... Thanks
pinellas50
New Guy
Re: Boost Solenoid Question
Nothing connects to it. I don't know why it is there but there is no hose, wire, or anything else that goes to it.
Ian Turgeon
Cascading Inspiration
Should be like this:
The other one HAD a foam block shaped filter on it... they all wear off. Its the vent for the solenoid.
Foot Performance
jhj said:
There was a factory air filter (POS) on it.
THat is what I thought
Not to Hijack but my truck hasnt been building boost like it should and was gunna buy one of those 15 dollar jobs on ebay to eleminate the solenoid as a cuase anyone try them??? Not long term just to test
bezerk
if you eleminate that. you are asking for codes. problems and a headache.
or do you have a chip? and datalog your truck
Foot Performance
I just want to test to see if the turbo will build boost or it there is somehting wrong with wastegate I I put a manual controller on and it runs fine I sould know there is something wrong in the boost signal or the solenoid itself butI will put it back once I eleminate some stuff :tup:
bezerk
if you have knock the stock ecm/chip will cut back on boost.
pinellas50
New Guy
Again, I learn something new. Mine has nothing and I remember reading other posts about nothing being hooked up to it. I'm assuming that air filter thing was not necessary.?.
bezerk
the air filter was a small piece if foam. nothing to worry abut
Foot Performance
Yeah I ordered my tuning stuff last monday so it should be here any day I will log it and see what is up hoepfully something simple but i thought a manual controller could be used to test :tup:
