Slyclone
Well-known member
Truck came with a autometer boost gauge never hooked up. I purchased some autometer copper line I think its 1/8 diam tubing.
I had issues with truck running rich, smoking and all sorts of crazy stuff. Chased my tail for a long time replacing what I thought were bad parts. dist module, replaced all plugs and wires, 02 sensor, and I think the last sensor was the ECT sensor which control the signal to ECU for engine warm up.. last ditch effort in hoping it would mend the rich run condition or stop it from over fueling.
Im moving the truck tomorrow and just had it started I was working on something under the dash and I notice sparks. Right away I thought I am going to have a fire. (something not seen during day under dash) electrical gremlins
My question is- Is the copper tubing causing a problem here? It is making metal on metal contact at the compression fitting (RPM booster fitting setup) and I found a existant hole and ran my copper through the fire wall and snaked it up the pillar with a nice short run and gradual bend. I moved something and seen the sparks and it arc out all over. How can it be picking up juice and I wonder if this is the little bugger that has hindered me for the past 2 years? Is the copper a mistake and causing a issue?
