boost controller, yes or no?
fiveoh
Enforcing traffic laws
are they worth buying, i know they are cheap, but dont know if i really need one. let me know what you think!
Syonara
Re: boost controller, yes or no?
Yesh--some let you control the boost levels in each gear!
Boost out of the hole @ 16psi and then 22psi in the next gear......very nice toy!
ghettosled
SYTY SUPERSTORE
if you are running a stock configuration (injectors/internal wastegate) then you can control boost with the ultimate chip and dont need to buy one. Thats probably a better investment.
Tydriver
TurboLS6 Powa'
Some people knock a "BOOST VALVE" setup.. However I have seen 2 separate people that have them and are quite happy with them..
www.boostvalve.com
Dont confuse them with grainger type or bleeder valve, they are NOT the same.. The boost valve is quite a bit better.. And you cant argue with the price..
crashing_sux
Blow Me?
I keep hearing about controlling boost with an ultimate chip. Does the ultimate chip do things you can't do by just reprogramming a bin or is it just the usual name for a custom bin?
crashing_sux
Blow Me?
Hmmm...nothing, maybe if i restate the question? Can I use my factory ecm for boost control if I'm burning my own chips or do I need an Ultimate?
bezerk
with the ultimate you can toggle true different programs, each program has their own boost settings, so bassicly you can control boost with the chip, altough you need a 3 bar map sensor
Wes
I have been very happy with the performance of the Blitz dual sbc R, this is on an external gate but I imagine it would also work well with the stock wastegate.
ZR1 S10
Do you have a link to one of these boost controllers?
mrweelr
Just ordered a Blitz SBCidII at a ridiculous cost of $475, but apparently the Ultimate 50# chip has boost control removed so I'll be using it for fuel and timing, but the Blitz for boost control with an external gate. Expensive, but worth it IMO.
sy#2716
SyTy 4 Life
www.raceprovenmotors.com
has the innovaitve msbc boost controller and that is what all the big boys are using
like ed hess, Matt& Doc hoover.
But i have one but have not had the time to get it installed yet but it is a very nice peice but also very expensive also.
but there are some good ones out there but if you want the best get the innovative one.
