Tooky
Serious about performance
I got my new cam installed tonight and when I went to install my Edelbrock #7801 double roller, it seems like I'm getting some interference. When I change back to the stock cam sprocket, it rotates smoothly. I put a dab of assembly lube on the block where I thought it was hitting, and put the Edelbrock sprocket on. It left a tell-tale mark on the sprocket.
Is this normal? Is it safe and correct to grind the block with a die grinder? Obviously I'll have to make an "apron" or something to keep any shavings from going into the motor.
I bought this timing chain on a recommendation that everyone uses these in SyTys... I searched and couldn't find anyone else who has this problem. Did I forget something when I reinstalled the cam? I put the cam in, the dark blue torx-bolted retainer plate, and then put the timing sprocket directly on that, seating the dowel pin. If there was something that fits between those two, I'd have enough clearance.
