Andreas
Any one have a calibration file to send me?
Just to have a base to start with.
andreas2073@hotmail.com
try to mail andreas one this mail :tup:denny said:The following recipient(s) could not be reached:
andreas2073@hotmail.com on 12/11/2007 2:23 PM
The e-mail account does not exist at the organization this message was sent to. Check the e-mail address, or contact the recipient directly to find out the correct address.
< imbaspam-ny05.iplex.ssmb.com #5.1.1 SMTP; 550 Requested action not taken: mailbox unavailable>
Andreas said:Started installing the BS3 tonight and came across the white AGS box that bolted onto the bracket for the stock computor.
From what I understand from this thread http://www.syty.net/forums/showthread.php?t=48313&page=2&pp=15&highlight=ags the AGS box is for the speedo and stays in the truck using BS3, right?
This connector is for the future 80E tranny right?
Andreas said:Thanks Ralph
Injector swap and some finishing touches of the placement of the BS3 box, after that I hope its starts.
One thought thou...what controlls the lock up solenoid for the TC when running a 700R4 and BS3.
A - F bridging with a manual switch?
ViciousV6 said:If your running a piggy back harness into your stock harness off the BS3 or do you have the full stand alone LS1 Harness like me. Stand Alone Harness you must get a B & M or TCI Lock - Up control in order to do so.
Piggy Back Harness Should do it through the computer like Stock!
Ralph
Andreas said:Hi Denny,
A ohm-meter for checking the pin# at the connectors into the BS3 box and then look at the pages in the end of manual would tell what tha orange is for.
