Where's the best place? Oil & water temperature & oil pressure. Anybody can post pictures where to mount them will be a bonus. Thanks in advance
i think he means the senders for the gauges, not the gauges them self. For water temp i would use one of the plugs on the drivers side head. The oil pressure i would tie it in with the factory one at the rear center of the intake.
oil depends on what you have in there already. I have mine coming out of the driver's side where the stock oil feed used to come from. The oil pressure sender is a tight fit already and will be a pain to install if you can find the right adapter.
The coolant temperature on the driver side means disconnecting the sensor to the gauges - it's probably not something you care about but it would annoy me, even if it doesn't read accurately to begin with.
Don't the water pumps have a plug in them? You could mount the sender there perhaps.
Sorry for the confusion.
There are a few extra ports on the block- Coolant ports. Driver side has 1 and the passanger side I believe runs the STOCK turbo coolant port- I have mine blocked/plugged.
I have been skeptical about running or plumbing a hard oil line inside the interior.
A leak could be a real disaster. but what do I know
