belltech rear sway bar(need pics)
jwaller
Evil Genius/SyTy Guru
just wondering if anybody has pics of their rear belltech 1" bar install with a SY and Stock ride height and springs.
GM TURBO
Sell Out
Re: belltech rear sway bar(need pics)
John - I somewhat remember the directions - what exactly are you looking for?
jwaller
well, I've got it mounted as you see here.
but I was wondering if you had to drill the frame as it says or did you use the holes that were in the frame at a location that looks very close to where they should be. onlyl prob is on the drivers side that hole is covered by the rear fuel tank strap
GM TURBO
Sell Out
The directions say to drill - I used the exsisting holes (but this was on a Ty). No tank strap to worry about.
The one thing I do remember is on stock height the L brackets the L should be flipped so it doesn't look like an L.
__
More like that.
jwaller
ya I saw on here somewhere when I searched a L bracket, actually it was the only belltech pic I found, it was of a L bracket(modified), problem is the kit I have didn't come with any L bracket. only the long bolts for each end of the bar. and those ends are what look like the bar ends are the ones that have the make the bushing sandwich on each end of it.
jbone
mine squeek when there is someone sitting in the back seat. I think it might be the bolts and the sway bar coming contact with and catching the clamp that on the leaf springs. anyone else have this prob. solutions???
