Bel Rear Sway Bar !! Making It Clear.
storm
This is the best freggin upgrade you can do !!, better than brakes, or steering shaft in my book,
Last night I installed the rear bar ( snap ) and front poly sway bar bushings. All I can say is you no longer have to follow the posted limit around the corners. :tup:
Quickstop [UK]
Combating adversyty.
Re: Bel Rear Sway Bar !! Making It Clear.
That is good to hear. Mine is on its way. Guess I need the sway bar bushings though. Where from? What did you get?
sy2675
He Saved the Pimp'n Game!
what brands? how much? Sy or TY? how long on the install?
GM TURBO
Sell Out
I'd guess he is referring to the Belltech rear sway bar. Any rear sway bar will be any upgrade from nothing.
Quickstop [UK]
which model did you get? BEL 5524 or 5525. Horrible feeling I bought the 5524 which is a smaller diameter.. :( 1 inch versus 1 1/4
storm
Belltech BEL-5520 summit racing 144.00, energy suspension bushings (front) ENS-3-5186G 24.00
after evaluating the weight of my syclone and its distribution, also wanting to keep the front bar stock as I want it tight but neutral, being a awd unit you want that for maximum grip, The larger bar might be right for a TY if you weight it out. But IT IS TOO BIG for a sy with a stocker up front.
Was a breeze to install no holes to drill they are already there just remove the back up fuel tank bracket (does not do anything) had it all done in about 20 min. Took longer to jack it up and find the tools than to install.
jimmyz79
Re-Member
I have not put it on yet, but I also bought the smaller (1") style and heres why. I once had a Big Bronco in which I put on a huge rear bar. The vehicle did handle better, but when I pushed it hard into a corner, the bar was so unforgiving that the rear axle would hop around the corner. It was also very bad in the rain, I was sideways on many occasions, I ended up removing it. Hoping this bar on the TY won't do that, cause the Ty will be going around corners faster than that big hulking Bronco.
hatrik8
bel-5520 bel-5524 bel-5525
What's the difference between them all?
live1053rulz
Nor Cal SyTy
They did make a great difference for me. I have front and rear Belltechs for a Ty for sale if anyone is interested. No longer need them since I did coilovers and custom rear leafs. They were a great mod, blew my mind. Pretty easy install too, especially for the rear.
sytyrod
what is the price delivered to 12919?
attackdog
Do you want to sell it? If so, how much including shipping to Toledo, Ohio 43613? Thanks.
-Deano
hatrik8
Does the Typhoon specific sway bar fit a syclone? Is the 1 1/4inch bar better than the 1inch?
Bel-5520 Sway Bar, Rear, 1 in. Diameter, Steel, Silver, Chevy/ GMC/ Isuzu, Kit
Bel-5525 Sway Bar, Rear, 1 1/ 4 in. Diameter, Steel, Silver, GMC, Typhoon, Kit
Bel-5524 Sway Bar, Rear, 1 in. Diameter, Steel, Silver, Chevy/ GMC, S10 Blazer/ S15 Jimmy/ Typhoon, Kit
pbrito28
Ty #2065 Brazil
I bought mine from RPM (Bel 5525) and notice a huge difference from the first corner!
Truck corner MUCH better!!!
jbone
I noticed a huge differnce without even turning!! I agree. there are few mods that I have made to my truck that have made that big of a difference. as a matter of fact I can only think of one and thats the turbo :D
hatrik8
Raceprovenmotors has 5524 as the bar for the SY and 5525 as the bar for the TY.
I know 5520 is definitely SY
5524 and 5525 are both TY only then.
RPM must have the wrong p/n on their website?
Quickstop [UK]
I just installed mine - noticed it as I was gewttting into the truck. Now I can go round corners sideways!!
This bar rocks - or rather it doesn't!!!
Grimgrak
Unfortunately mine came with a few missing parts and a few extra washers...
Is there any write up or guide on how this isntall was done?
live1053rulz
Nor Cal SyTy
What parts are you missing? I don't see brackets that mount to the frame. I think mine came with instrusctions, but it was kinda self explanatory. Makes a lot more sense if you have all the parts though.
