Battery relocation question
jjorgensen52
NHSTE - I'm the only one!
Has anyone ever relocated their battery to the driver's side where the ABS block is? I just bought an RPM intercooler and need to relocate it, but don't want to put it in the back of the truck.... and I want to keep the oiling system intact.
hideakimura
NipponSyTy
Re: Battery relocation question
My friend Ross-san did it w/o ABS deleted, and mounted oil filter there.
Horse Power
Horse Power
Mine was relocated in front of the right rear tire when I bought my truck to make way for an air filter mod. It was not that much of a problem to jump with a set up of wire run into the engine compartment, until I installed my air to air intercooler. Now it is a little bit cramped. I also have to work to get it disconnected directly at the battery with a small wrench of some sort. ATR has a kit. web sight "atrperformance.com" I'm pretty sure.
NecroWolf
lost marbles member
not to steel the thread but that's an awesome battery hold down, where'd he score that at?
Jer
Don't taze me bro!
I've seen similar on eBay and my frist thought was that if you used a standard top mount it would ground out on the trim piece that runs right next to the post.
