Re: battery lifespan???
...Found on the Internet:
Optima has long been the default "best" expensive battery for the muscle car and hot rod owners. Unfortunately,
since the manufacturing location was moved from the States to Mexico a few years back, there have been a high
incident of returns and complaints on several car forums. Also, Optima Battery isn't honoring all of its warranty provisions.
Instead of allowing consumers to go to any authorized Optima dealership or distributor for warranty service, as their
written warranty maintains - Optima Battery insists consumers only get service from the company that sold them their battery.
Four companies make most of the car batteries. East Penn Deka, Johnson controls, AC Delco and Exide.
Exide went bankrupt and Johnson Controls (Kirkland, Optima and Interstate) moved to Mexico and with their product
(quality control) suffering. Some brands last for years but also fail quickly. Companies manufacture batteries to their customer's specs.
Walmart for example, will order different specs and the battery is NOT the same as other batteries made by that manufacturer.
Big-name battery brands DieHard (Sears and Kmart), EverStart (Walmart), and Interstate all top Consumer Reports Ratings in some group
sizes, but they are at or near the bottom in others. The greatest inconsistency by magazines came from DieHard, which makes both the best and worst
performers in two of six common sizes tested. Some great batteries are made overseas. Korea and the Phillipines make some of the best standard
flooded lead acid.
...Personally:
I been told it is HEAT that kills batteries but cold required more cranking amps to turn over a starter and engine.
I long suspected vibration also plays a role as well (but have no proof). Supposedly AGM batteries are "best in class"
with Oddessy the most preferred. But AGM is expensive. If you have remotely located your battery to the rear and drive
your vehicle sparingly you might want "no spillage", "deep cycling/charging", "large cranking amps", and a reasonable size-weight
battery that can be accessed via a Smart Charger during storage.
-Larry Brown
NoJimmy AWD LS7 Typhoon
