carVSsuv
So there I was......
About 18k miles ago I had my front diff go out in my truck and fixed it. Then I had 17's in the front and 18's in the rear sized matched for diameter. since I never went lock to lock on turning because the wheels were to big, I never saw the total symptoms of bad VC. When I rebuilt the front diff, I put stock wheels on it but it still seems that it didnt like to turn when wheel was turned lock to lock and I had my suspicions.
I drove the truck on stock wheels for a long time but wore the front tires out on the insides and outsides and thought it might be an alignment still in the back of my mind thinking the VC is probably almost toast.
I got the truck painted and put the 18's on the front and rear with good tires. Since I still had the problem with the large wheels I wouldnt go lock to lock at all, thus nobody drove my truck.
Well today I was making a U turn on a three lane road and as I am finishing the turn and powering out. BAMM!! and no power! truck is running sounds good oil pressure good but not moving forward and its just rolling to the side of the road..
Looking on the road there was a piece of the front yoke for the TC on the ground but both drive shafts are still in. The front prop shaft is actually a gilbert so the next weakest point would be the yoke and then tranny fluid starts to run down the side.
So tomorrow I get into tearing into it.
What concerns me is that even with the truck in park I could push it. That makes me think that TC locked up and is no longer connected to the transmission and that there is damage to the side of the pan I cant see because of my stature of my truck.
What is the best place to get parts for the TC for a rebuild or does anybody have one that is in good condition with a good VC?
